S80 1999 SRS warning urgent light, code 26, how to rest
Hi Guys,
This is my first post so here we go. I have a S80 1999 and the light and message 'SRS service urgent' has come on. I have done some research and did the following: 1. Press the odometer reset button 2 put the key in and turned it to pos 1. 3. After 10 secs the message screen has the number 26 4. Tried to turn key to pos 11 for a further 5 secs to reset meesage but it will not reset. I think was caused the light to come was a very hot day and I opened all 4 electric windows before starting the motor. I suspect this caused the voltage to drop and cause the error message. We also have the occasional message 'low voltage' message but the car starts OK. Buy I guess the battery is weak So my questions are as follows: Q1 What is code 26 mean? Can't find this anywhere. Q2 Can I reset the SRS light at home? I read something about the battery being disconnected causes it to come on but you may have to disconnect the battery for 15 minutes. Any suggestion greatly appreciated. Marke. |
Bump to the top, any ideas anyone?
I've disconnected my battery for longer then 15 minutes on my 2005 S80 and it has not affected the SRS system or generated a warning. I'd probably take it in to be checked out, the SRS system isn't something you want to mess around with.
