-   Volvo S80 (https://volvoforums.com/forum/volvo-s80-18/)
-   -   S80 battery replacement leads to new air bag! (https://volvoforums.com/forum/volvo-s80-18/s80-battery-replacement-leads-new-air-bag-16277/)
STMullins 12-28-2007 01:48 PM
I have a 2000 S80 that needed a new battery. After it was replaced the SRS error light was on. I took it to the dealership and they accessed it and tried to reset it. However, they said there were TWO error codes in the computer. One for the battery reset and one for an error with the driver seat side air bag. They said this now needs to be replaced at a cost of $975. This all happened right after replacing the battery. Assuming I ever replace my battery again, is there anything I can do to protect against this happening?
Also, is this just a computer chip I can buy and replace myself?
team 12-28-2007 02:01 PM
RE: S80 battery replacement leads to new air bag!
just have them reset the codes and go from there. mine came on after a new battery, had them reset the code and all was fine.
STMullins 12-28-2007 06:37 PM
They did reset the code for the initial 'loss of communication' error, however the fault in the driver side air bag is real (and according to them, coincidental). I don't believe in coincidences and believe its related to the battery replacement. Can I replace this myself? Does anyone know where I can get service manuals?
team 12-28-2007 07:07 PM
have you had the latest software updates?
tech 12-28-2007 10:22 PM
I have changed hundreds of batterys in the S80's and never seen this before.
The code is listed as a permanent fault?
STMullins 12-29-2007 04:50 PM
What software are you referring to? If its the on board computer stuff, then I ASSUME so.
STMullins 12-29-2007 04:52 PM
They say its permanent.
tech 12-29-2007 05:13 PM
That is very weird.
