S80 Ghost?????
Hi team I am new here and have a 99 S80 T6 and have a few issues.
1-Car off nothing on then come back to car the heater fan is running??? 2-Sun roof and remote locks dont work ( remotes good) 3-Air bag urgent note is on?? 4- engine oil leak near trany Main seal??? 5-Navigation system need Canada maps at cheap prices will trade for USA maps. Any help on any subjects would be great |
As for the fan running, that is normal operation. Usually comes on after twenty minutes of engine off to blow away condensation on A/C to prevent mildew.
The heater fan will blow? not the rad fan. is this ok?
The blower motor inside the passenger compartment will be the one blowing. The radiator fan will do its own thing separately.
1. Yes normal it is called an afterblow function to dry the evaperator so mold will not grow on it.
2. You might have a bad alarm siren. That will stop the sunroof and locks from working properly. 3. You need to have the codes pulled. 4. The oil leak can be many things you need to clean it good and drive it a little and recheck it. 5. Sorry not sure about this one. |
Thanks Tech where is the alarm siren located? can it be disconected?
It is in the R/F fender liner. You cannot just disconnect it.
Navi disk- Have you tried ebay?
May take awhile but everything seems to show up there if you look often enough. |
