S80 with no power after battery died
I have a 04 S80 that the battery died in and after recharging the battery I no longer have any electrical in the car. Interior lights, dome lights, etc. Nothing... Any suggestions? |
you didn't say if you can start the car. if you have a volt meter check the voltage across the battery terminals. Next is inspect the cables to the battery. clean the posts and retighten, inspect the ground strap etc. If you have 12.6 V at the battery and no interior lights, check for voltage at the fuse box, then check all the fuses.
