-   Volvo S80 (https://volvoforums.com/forum/volvo-s80-18/)
-   -   S80 T6, dead #4 and #5 cyl. (https://volvoforums.com/forum/volvo-s80-18/s80-t6-dead-4-5-cyl-73033/)
blk07dub 08-21-2013 01:49 PM
Hey guys ! new to the forums...
Let me start from the beginning, I bought a 00 T6 with 150k off Craigslist ( Cheap ) being told it needed a headgasket. (story has it the p/o ran it hot due to WP failure) my seller did a wp and timing belt job only to find it needed a headgasket...
Fast forward bought it, brought it home, started looking it found the the "oil" in the coolant was trans fluid and no coolant in the trans. SCORE !!
BUTTTT I still have a rough idle, so I assumed he had not set the timing correct.. so i lined everything up and everything looks good ...
Found the #4 & #5 are "dead" swapped coils around, swapped plugs (#4 and #5 were wet from fuel), swapped injectors, and also did a compression test all 6 are 170 -180 ish... tested voltage to coils ( 4 and 5 ) against others and all seems the same.
My question is, if the Exhaust cam is out a bit will that cause a mis on just two Cyls ? :confused:
Thanks Guys !
Disco2 08-21-2013 01:56 PM
You swapped coils, plugs, and injectors. Don't suppose you swapped the coil wire connectors between 4 & 5? Just a thought....
blk07dub 08-21-2013 03:55 PM
no I did not try to swap connectors. but in doing that that will mess the firing order up correct ?
blk07dub 08-21-2013 04:02 PM
ahhhhh you are implying they had it wrong to begin with !! and you sir are correct !!!!! Just switched them and smooooth has butter !!! although i will say the #4 connector seems short... very odd !! THANK YOU !!
Disco2 08-21-2013 07:41 PM
You're welcome :) Glad it worked out. I think Volvo did that on purpose. They probably get quite a few people that come in with that misfire issue then charge them $100 to "fix" it :rolleyes:
