S80 T6 Help needed !
New member with S80 T6 (2000) question.....
Bought it used in August, and it's been excellent till now (72K on odometer) My turbo(s) started fluctuating a few weeks ago, only a little and not to often (at first). Shortly there after I got "Emissions Service Required" in the message center. a few days later while driving, the message center displayed "Performance Reduced" and it was! felt like the turbo(s) where not even there, but then they would kick in and out. The next day coming home from work same two messages above came up plus a new one "Engine Service Urgent". the car felt like it was going to quit ant any moment. I have parked it and did some research and suspect the "Boost Solenoid". My questions..... Does that all sound right ? Can I replace the solenoid my self ? Is there more going on here than I realize, or can the solenoid alone cause that much havoc. Any advise is GREATLY appreciated... Thanks |
RE: S80 T6 Help needed !
You should have the codes pulled.The throttle body is known to go bad on these things.It will cause the problems you feel on the car.If it is the throttle body you might want to have the dealer do it.If not you can replace it then have it towed to the dealer so they can load the software.The software is needed for the car to run properly.The valve rarely goes bad on these cars.
Thanks for the info, it's greatly appreciated... : )
(I miss driving that car, not that I'm complaining about my V70 XC) |
