S80 turn signals
my turn signals stopped working so did the intermittent wiper, high beams and the message center\, anyone have an idea what is wrong..thanks
Does the horn work?
S80 turn signals
yes the horn works, but the high beams, washer fluid do not work
fuse problem?
Did you check the fuse panel? You'll have look in your book about which location house the fuses to look for. Fuses are cheap but very hard to pull out and look at them closely to determine if they need replacement.
S80 turn signals
I found the problem, it was a plug in the steering column that came apart. Thanks for the help!!!
