You didn't mention a year.....
From IPD, the following;
HOWTO: Reset Service Reminder Indicator on 1998-2009 Volvos
Tuesday, August 25, 2009
Some 1998 and older models require a OBDII service light reset tool. You can probably have it reset for a marginal cost by a local Volvo dealership or Volvo specialty shop that has one of these tools.
1998 Volvo S80 Models - Turn ignition switch to position I
- Press and hold the odometer reset button
- Turn ignition switch to position II
- After Service light flashes, release odometer reset button
- Turn ignition off
- Turn ignition back on to confirm reset
1999-2000 Volvo S70 / V70 / C70 Models - Insert key in to ignition but don't turn it yet
- Press and Hold the odometer trip counter reset button
- Turn ignition switch to "run" position (Position II)
- Turn ignition off
1999-2000 Volvo S80 Models - Insert key and turn ignition switch to position I
- Press and hold odometer trip counter reset button
- Continue holding odometer trip counter reset button for about 10 seconds
- Should hear "beep-beep" to confirm command accepted
2001 Volvo S80 / V70 / S60 Models (May apply to S40/V40 also) - The service reminder indicator lamp illuminates for 120 seconds when the ignition is first switched on.
- Insert key and turn Ignition Switch to position I
- Press and hold in the reset button for the trip odometer
- Turn the Ignition switch to position II (within 5 seconds)
- The service reminder indicator starts flashing when the reset button for the trip odometer has been pressed for 10 seconds
- Release the reset button for the trip odometer within 5 seconds. The instrument gives an audible signal when resetting has succeeded.
- If the trip meter reset button is not released within 5 seconds the indicator is not reset, but the indicator will stop flashing.
2002-2007 All Volvo Models
- Turn the Ignition switch to position II (within 2 seconds)
- Hold the reset button for the trip meter pressed in until the original trip counter value blinks and is redisplayed
(For all vehicles 2003- a general yellow lamp will light when the reset button must be released.)
- Release the reset button for the trip odometer within 4 seconds. The instrument gives an audible signal when resetting has succeeded
- If the trip meter is already reset the reset button should be held in for a minimum of 10 seconds and a maximum of 14 seconds.
- If the reset button for the trip odometer is not released within 4 seconds, the service reminder indicator (SRI) is not reset.
2008-2009 Volvos with starter push button on dashboard - The trip odometer must have at least 0.1 mile on it or the light will not reset.
- Get in vehicle and do not push down on the brake pedal
- Put the key in the slot and push the starter button once
- Press and hold down the odometer reset button
- While doing this, push the starter button again and hold for 2 seconds
- Keep the odometer reset button held in and watch the instrument cluster for the general warning indicator (I) to illuminate. When this happens, release the button.
- Turn the vehicle off then back on and verify the message is now out.
