SRS
Ok, i was messing with my fuses to make sure they were in the correct order, which they were not, so i moved the right ones into the correct places. I thought everything was fixed till i started my volvo, I received an error message saying," SRS-Airbag Service Urgent."
What seems to be the porblem and how can I fix it? Can I just take it up to Advanced Auto Parts and have them hook up a module and clear it for me? Thanks |
RE: SRS
Probably not. Most places don't have the readers to clear air bag codes. I had to take mine to the dealer. They did this one for free only because they had made a mistake about something else they said they could do and turned out they couldn't. But normally I think was $45 here.
RE: SRS
Is it dangerous for me to drive around though?
RE: SRS
They won't go off by themselves but may not go off in case of accident.
RE: SRS
Ok, cos I was going out of town this weekend and was not sure if it was safe to drive like 3 hours?
RE: SRS
You should be fine.
RE: SRS
What would be the problem that is causing this light to come on? Also, how can I fix it? Will taking it to the volvo dealership and having them reset it fix the problem?
RE: SRS
Power loss can cause the light to come on. Usually just clearing the codes works.
RE: SRS
Alright! Thanks for all the help! I'll let you know what happens once I take it to the dealership.
RE: SRS
Sounds good.
RE: SRS
Any update on what went on at the dealership? I'm curious about the error codes because once I got the dreaded position light code... but it was odd, there was no problem and it eventually cleared itself after a few hours..
