SRS-tech
Old Dec 23, 2005 | 01:06 PM
gordon368's Avatar
Default SRS-tech
Well went to my Volvo delearship, and am not happy at all....
Job #1 -
Customer States that srs airbag light is on SRS 007C seat belt tensioner, middle resistane too high 007A Copacitance to high. Wiring for aftermarket stereo still present on hat shelf & in left rear wheel well. Cust to reschedule when all wirein removed.
Tech, whats the code mean, and why do i have to remove all the wiring???? Its not even hooked up.....
Job #2 -
Customer states that when heat is on max & on high speed fan is very loud. Needs blower motor $440.00 - thing is after they looked at it, the noise went away.....
Where can i get the part number for this and where can I get it cheap? Is it easy to replace(can I do it myself)?
this is very dissappointing......
Old Dec 23, 2005 | 10:22 PM
Default RE: SRS-tech
I will have to look up the code tuesday.
The blower motor isn't all that bad. It just takes a little time.
No source on the parts.
Old Dec 24, 2005 | 01:42 AM
gordon368's Avatar
alright i await your response, adn what is involved in the blower motor installation?
Old Dec 24, 2005 | 10:21 AM
You will have to remove it from under the dash. Then you will have to remove a couple of screws to slide the blower motor out of the plastic housing.
Old Dec 24, 2005 | 10:34 PM
gordon368's Avatar
The way you put it sounds too easy, ahahah, do u have a place where i can see the instructions for it....?
Or is it this....... for instructions,
1.) remove dash
2.)unscrew blower motor
3.) put in new blower
what do you think is the total estimated time on doing this?
I realized somehting, when Volvo erased the DTC's the message was gone on my dash computer. When i folded down the driver side back seat, the message came back on...
Could that be the problem with the srs system, right when i folded down the seat the SRS service urgent message came up?
Thanks tech
Old Dec 25, 2005 | 12:56 AM
The lower dash I believe has 2 screws holding it on. Then unscrew the blower motor and replace.
It may take an Hour tops since it is the first time.
That sounds like it may be the problem in the seat. The seatbelts are tied into the SRS system. Try to check the wiring on the side of the seat close to the door. It is where the seat bolts to the floor.
Sparky4688
Sep 26, 2009 06:22 AM
knight rider
Oct 10, 2008 07:41 AM
knight rider
Jan 17, 2005 02:39 PM
knight rider
Dec 30, 2004 01:11 AM
larese
Dec 1, 2004 01:04 AM
