Stop Lamp Brake Lights
Check Stop Lights keeps popping up on the dashboard. After a few minutes or several steps on the pedal the message goes away. The lights work. But it keeps failing everyday.
I replaced the stoplamp switch on the brake pedal. Still not working correctly. I replaced the two bulbs in the rear, still not working correctly. Eventually they work so there must be something else wrong. I have a DiCE and ViDA it it tells me that nothing is wrong!? I've checked the fuses also. All good. Is there a relay that may be failing? If so, where is it? Any suggestions are appreciated. 2001 S80 2.9 |
My solution was to replace the stop lamp relay found in the REM. Everything works great now!
