surgeing problem
Have a 2001 S80 2.9 non turbo 95000 thousand miles Dealer says new software has been loaded. I am have a surgeing problem at low speed Some times when you are just creeping along it will almost jump out from under you as it will surge foward Also when you come to a stop it will surge foward does not seem to have a problem at higher speeds any ideas
RE: surgeing problem
Has the throttle body been cleaned yet?
I dont know have only had the car 8 mos Is this something that would be covered under the warrenty Volvo extended? If not I have a good mech at the Ford store Could he clean it without any problems?
I would start by having it cleaned.
No it will not be covered under Warranty. |
