Tech!!! HELLPP
99' T6 floored it earlier and it cut out for split seccond.. now if i revi it up at all it sounds like a rubber ducky beeing squeezed.. you can only hear the rubber duck while the RPM's are droping when you let off the gas.. ITS GUTLESS now.. PLEASE tell me the turbo aint shot ill shoot myself
RE: Tech!!! HELLPP
Sounds to me like you blew a hose when you floored it. Pop the hood and check for a loose IC hose or something.
If not maybe someone else has some advice?? |
RE: Tech!!! HELLPP
2 Attachment(s)
ok what is this..... the sound is coming from whatever this part is that seems to have blown out. one of the tabs broke off...
Attachment 23696 Attachment 23697 |
RE: Tech!!! HELLPP
That I think is the boost pressure sensor.
You should be able to put it back in for now then hold it in with a wire tie till you get a new one. |
RE: Tech!!! HELLPP
yea im a helicopter mechanic so i had some safetywire.. i installed a slightly larger (thicker) packing on it and put it back on and secured it with safety wire.. works like a charm. i have a feeling i have been getting blowby from that point since ive had the car.. thanks!
That is the air intake temperature sensor.
