Tech Question
Tech,
I have replaced my HU-801 i believe in my '00 S80. Once i have put my radio, Climate control module, etc.. back in my information screen on my gauge cluster says " SRS Service Urgent". This had happened previously when i was running wires through my center console. Last time i brought it to my local dealer and they said that it was an erroneous code in the system, and rewrote the code. It was fine up until the install of my new radio. When this service light happened again. I am assuming that it is again an erroneous code in the system. But my question was, does the SRS system run in a circut through the Radio/ Climate Control Module, and is that why this light goes off everytime i disconnect either of those things? Breandan |
RE: Tech Question
It is kind of tied to the systems. The radio is a module in part of a network. Did you install an aftermarket radio?
If so you should really get a software download to remove the OEM radio as a module. |
RE: Tech Question
yes i did install an aftermarket radio, i installed an alpine headunit. where would i go about downloading this software to remove the OEM radio as a module?
Breandan |
RE: Tech Question
also how would i upload this software to my car?
Breandan |
RE: Tech Question
The Dealer will have to do it for you. Or a Volvo specialist shop that is able to do the downloads.
RE: Tech Question
thank you. how much do you believe that will run me?
RE: Tech Question
The software itself should be about $30.00 then between 1/2 hour and 1 hour labor.
RE: Tech Question
thanks
RE: Tech Question
Your welcome anytime.
RE: Tech Question
Anytime you are going to work with an electrical part on a VOLVO..make sure you DIS-CONNECT the NEGATIVE side of the battery First..then you won't get the SRS Warning on your dash..I know I found out the hard way also....even bought a SRS Erase Diagnostic tool in case I forget again, and since I did that..I will never forget again (Ithink)....
Originally Posted by air force rascal
(Post 132117)
I see that this thread is very old, but Im reading up on this issue and need advice from anywhere I can get it. I just bought a 2002 S80 and the previous owner had just replaced the battery and now the climate control is out as well as the SRS urgent message in the dash. Im wondering if your still on here, what scanner you bought that will clear this code and make the climate control work again. Crossing my fingers. Thanks
Originally Posted by ingydrummer
(Post 379493)
