Throttle body
Tech, I would like to clean the throttle bodyon my S80, there's no problems but I've read a lot of incidents where owners have problems due to build up. Can you guide me through the process? Also, thank you for the help on replacing my serpentine belt. With your help I've actually saved about 1500 in repairs.
RE: Throttle body
I forget is it turbo or non-turbo?
RE: Throttle body
Non turbo
RE: Throttle body
Buy a throttle body gasket first.
Then remove the hose going to the throttle body.Next unscrew the throttle body and remove. You might have to remove the bracket on the back of the starter.It will be 2 10mm nuts and 1 12mm screw.That will allow the wiring to come out from the starter. Then clean with Carb cleaner. |
RE: Throttle body
I'll do that this weekend, thanks tech
RE: Throttle body
No problem let me know how it goes!!
