Throttle body cleaned
Just had dealer clean the throttle body for 85.00 no problem with charge thought it was fair but while it has helped my surging a bunch I still get some surging at times did not correct problem all togeather what is my next step?
RE: Throttle body cleaned
See if it gets worse and maybe will throw a code.
Hopefully it will throw a throttle body code soon so you can get it replaced. |
ORIGINAL: tech See if it gets worse and maybe will throw a code. Hopefully it will throw a throttle body code soon so you can get it replaced. |
No they would replace unless there is codes. No way to force the codes either.
