timing belt
Is there a DIY for replacing the timing belt, tensioner, idle etc for a 2000 volvo s80? Pictures would be preferred.
RE: timing belt
Why, yes, there is... ;) search is your friend!... look for "75ohm's 2000 s80 timing belt replacement"
RE: timing belt
I was actually looking for one with a little bit more pictures if possible. I am interested in doing this so what is the best place to buy the whole kit (timing belt, tensioner, idle) online or can I buy it at a local car store like Murray's?
RE: timing belt
Maybe the overseas haynes manual has it? Not sure...
What specifically are you looking for? |
RE: timing belt
Have you ever taken on a car repair this large? You can really mess up your car's engine if you mess this up.
RE: timing belt
I think I will take it to a service, I don't want to risk damaging anything. Can regular car services do it or does it have to be a volvo dealership?
RE: timing belt
It doesn't have to a Volvo dealership, but you'll definately want to take it to someone that is familiar with major engine repairs rather then just a place like PepBoys, Midas or the like. I'd probably stay with at least a European specialist for repairs.
RE: timing belt
Where are you located? There may be places that local folks will recommend to you...
RE: timing belt
I am located in grosse pointe, michigan. If someone can recommend me some good mechanic I would appreciate it.
RE: timing belt
Well, I don't think a road trip is going to happen, Nertil, apologies... anyone in the area that can recommend a shop?
RE: timing belt
Ok guys I found a volvo dealership and they told me 545+tax for the timing belt and the tensioner. What do you guys think?
RE: timing belt
Thats a good price.
RE: timing belt
Make sure they do the idler pulley (roller) as well... that is a good price, agreed.
RE: timing belt
I asked them about it an they said they do not. Is it really that important?
RE: timing belt
Absolutely.
RE: timing belt
It turns out that the previous owner had already replaced the timing belt, idle and tensioner this year before he sold it to the dealer where I bought it from. There is still kind of a rubbing noise coming from the engine and the dealership told me it is the auxiliary belt and he said that he can replace it for 175. Would it be easier/cheaper for me to change it myself or should I let the dealer do it?
P.S. Where is this belt located? thanks nertil |
RE: timing belt
The auxillary belt is also called a serpentine belt. It's not hard to change, just a tight fit. If you have patience, this is definately something that can be done by someone who a basic tool kit. You just have to make sure you route the belt properly.
You won't damage anything if its installed wrong, well besides possibly the new belt, but its not going to cause engine damage. |
RE: timing belt
Is that the belt that can be seen on the left side of the engine?
RE: timing belt
drivers side of the engine, yes
RE: timing belt
the passenger side one (on the cam gears) is the timing belt.
