Tips on general maintenance on S80
Hi.. :) ...
Just want to know if anyone there has any tips on Oiling/Geasing the S80.. that will help in No or Min squeaking all around the car? I.e. is there a need to put a bit of grease on the pulley's, shock absorbers etc? which will help in smooth/silent running on the vehicle.. PS: I seem to getting bit of squeaking sound around the car, but not able to loacte where the sound is originating... :confused: Any pointer? Thanks SS |
did you listen to the accessory belt ? it could be that, the bearings in the pulley could have worn out,
when is it happening ? all the time ? cold vs warm ? suspension when hitting bumps ? |
S80 gen maintenance..
Thx Andrei...
My car is a.... 2000 S80 Saloon... 88K done... bit random on when I hear the sound... |
I don't mean to assume anything, but are you sure that the sounds are coming from the suspention components or "pulleys"? It is very difficult to locate some sounds in a moving car
Try completely empting the car - the Glove box, center console, door pockets, seat back pockets, under the seats, trunk. I mean everything, even things you know couldn't possibly squeek. Check your spare/jack/tools for looseness. Then drive it, it's frequently dead silent after this "treatment". Then think about what you put back in (bet you leave half of it out!). |
