Trans slips after geting off Fwy
My trans will only slip from 1st to 2nd but only when I get off the fwy and after that it works normal.
I'm planning on changing trans fluid and filter, is there any thing else I should do when I have the pan off? |
Does changing the filter and fluid sound like a good plan for now? I have no trans codes. Has any one had this type of problem?
That might help!
Changing the filter on monday, going to use this info http://volvospeed.com/Repair/s80_transmission.html
I'm assuming that is the same trans as in my 2001. Can some one help me with torque spec's for the trans pan and filter? |
I'm assuming the trans slippage after fwy driving is due to high trans temp. What are your thoughts on that?
Has any one experimented with adding an extra trans cooler to there volvo? |
Have not tried an extra cooler as of yet. Sorry do not have the torque specs right at the moment.
Has any one experimented with adding an extra trans cooler to there volvo? I know you said you are doing the filter etc, but you never mentioned what the level is currently at and what the condition the fluid is in. |
When it's slipping are you giving it full throttle?
BTW I just changed my transmission fluid to synthetic and it made a pretty big difference. |
Its been a painful car to repair. I changed the trans fluid and filter, sliped in my garage and landed on the corner of my tool box and broke a rib.
Anyways, the torque spec's on the trans pan bolts are 10nm. When I got the vehicle the trans was about a qt low on fluid at norm opp temp. Fluid was alittle darker then honey. The trans has improved but it still isnt fixed, it takes more miles on the fwy before it starts to slip again. Once i get off the fwy after the first stop light the trans goes back to normal. Trans will slip at any throttle%. I'm going to put a small trans cooler on the vehicle in hopes to prolong the death of this trans, unless any one else has other idea's that dont involve me droping the trans. Thanks. |
Originally Posted by S802001
(Post 210365)
Every time I get off the fwy to try that, there is a car in front of me, this car picks up pretty fast and I don't want to end up having a post asking about repairing a front end.
I'll let you know what happens when I try this out. |
