Transmission issues
My transmission starts to slip after driving after about 30-45 minutes. Fluid is full but it drives perfectly fine until after that time range anyone have any solutions??!! |
I will assume that you have an S80 with the 6-cylinder engine and the GM transmission.
If so, typically, it is a sign of worn clutches and internals. As the fluid temperature increases it can't hold pressure on the drive clutches. Rebuild. |
It's the s80 AWD and I've been told that it could also be the transmission solenoid. I just really hope it's not a rebuild |
Which engine?
