transmission problem???
Old Jan 1, 2005 | 09:04 PM
roughyear's Avatar
Default transmission problem???
ihave a 2000 volvo S80 T6..
what i thought was an oil leaked has actually turned into a TRANSMISSION leak. i took my car to the dealership 2moths ago and told them i was noting an oil leak on my driveway. well after a $90 diagnostic they said "no oil leak"... well the damm thing continues to leak so i put a towel underneath the car and its RED/purple in color which i'm assuming is transmission fluid... am i correct??? must because the damm transmission fluid is low when i checked while it was running!
i just went back outside to look again.. i checked the transmission (ATF) dipstick and there was lots of fluid apparently all the way UPTO the HOT marker on the dipstick (the car had been sitting for about 3hours) .... suddenly i thought holy$hit it's leaking because its overfilled... so i drove the car about 5mins and checked the dipstick and now it is nearly empty (well below the COLD on the dipstick) ...
the marking on the dipstick are COLD near the bottom of the stick and HOT higer up... that's correct isn't it?? ... so why am i getting these funny readings???? help???
i can not get underneath the car to look exact at the source, does anyone have a clue... is it a gasket or bolt or is the darn thing dying.. it only has 87k miles.
Old Jan 2, 2005 | 12:12 PM
Default RE: transmission problem???
Most likely it is the transmission pan gasket.Those cars are very funny about trans fluid level.The level will some times read low when cold then normal when hot.You must check it when the car is good and hot.Make sure the level is to the hot line when the car is warm.I would take it back to the dealer and complain like crazy.Most of the time when the dealer looks at it if there is lots of fluid.They will clean the area real good then have you bring it back so they can look at it again to see where it is leaking from.Those trans. pan gaskets are known to leak.
mason3325
Dec 22, 2021 12:51 PM
jeffrisley
Jun 14, 2015 01:48 PM
scorp
Jun 27, 2007 08:47 PM
