Turn over but won't start
Hi guys
I have a 99 S80 and it turns over but it won't start. I have a message in the window ( immobilisation activated alarm status on ). Thanks in advance Rej |
RE: Turn over but won't start
That means there is a problem with the Immoblizer. Do you have another key you can try?
BTW I am moving this to the S80 section where it should be. |
Hello tech
Thanks for your quick response. I tried the second key and used it to lock and unlock the car and in the ignition and when I try tostart it will crank but won't start and it post the immobiliser in the window. Is there anything I can try to at least start it and get it to the dealer. I'm trying to save a tow truck. Thanks Rej |
Sorry no. The car doesn't see the key is in the ignition.
The antenna ring might be bad or it is something in the Immoblizer itself. |
What if I disconnect the negative from the battery for 5 minutes and reconnect. It may reset the alarm and fix the problem? It's a shot in the dark.
You never know give it a try.
Tried to disconnect the battery and it did not work. Sending it to Dealer on a tow truck. I'll report when I get it back.
Hi i have similar problem with my s80. Any news from your dealer on what might be causing the problem before i take my car in. Thanks
I believe there is a chip in the key. If this is true, make sure you have no other keys on your key ring which have a chip in them. They will interfere.
hi thanks for your suggestion but unfortunately i had to take the car in to the local dealer . He advised that we reprogramme the keys and the car but this did not work and it cost me. He has now said the CEM is busted and i need a new one and another set of keys. Can anyone else tell me what might be wrong before i blow too much money on guess work from my dealer.
