Volvo ECM ETM Throttle Body Coverage
Pulled this from the Volvo site and think now that all those in * are covered till 10yrs 200k.
Tech, is this right. 2000/2001 Emission Warranty Parts List - Federal - U.S. and Canada -------------------------------------------------------------------------------- The following are some items covered by the Emission Warranty for two (2) years or 24,000 miles/40,000 km, whichever occurs first. Volvo has continued coverage on these items under new car warranty to four (4) years or 50,000 miles/80,000 kilometers, whichever occurs first. This only applies to engines/models, components, or systems fitted with those items. Components marked with one "*" are covered by the Long Term Warranty for eight (8) years or 80,000 miles/130,000 km, whichever occurs first. Ignition System Ignition Coil with Integrated Power Stage Motronic Engine Control Module (ECM) * Spark Plugs Knock Sensor (KS) Engine Speed (RPM) Sensor Continuously Variable Valve Timing(CVVT) Air Assist Control Valve Ambient Temperature Sensor Electronic Throttle Module** Fuel Metering System Fuel Pressure Regulator Mass Air Flow (MAF) Sensor Multiport Fuel Injection (SFI) * Control Module Fuel Injectors Engine Coolant Temperature (ECT) Sensor Heated Oxygen Sensor(s)(HO2S) ** Not Applicable to S40/V40 Page 33 Fuel Metering System - continued Manifold Absolute Pressure (MAP) sensor Camshaft Position (CMP) Sensor Evaporative Emission System Fuel Filler Cap Vapor Storage Canister Fuel Filler Pipe Purge Control Valve Positive Crankcase Ventilation PCV Calibrated Orifice Air Intake System Intake Manifold Turbocharger (TC) Assembly TC Wastegate Actuator Charge Air Cooler (CAC) Catalyst System Three-way Catalytic * Converter (TWC) Exhaust Manifold Exhaust Pipe (Manifold to TWC) * Covered by the Long Term Defect and Performance Warranty for eight (8) years or 80,000 miles/130,000 kilometers, whichever occurs first. |
Ecm Outlet was able to repair my 2005 Volvo xc90
I sent this company my xc90 ecm and they repaired it. It no longer misfires as it did before. I thought my only option was the Volvo dealership but I was wrong. The name of the company is Ecm Outlet and the website is easy to find online. My xc90 is now driving as it did when I bought it in 2005. I hope this helps you in fixing your xc90.
