-   Volvo S80 (https://volvoforums.com/forum/volvo-s80-18/)
-   -   Volvo S80 Xenon Headlight assembly (https://volvoforums.com/forum/volvo-s80-18/volvo-s80-xenon-headlight-assembly-16566/)
woodrows80 Jan 9, 2008 02:06 PM
Would a Xenon Headlight (part #8678111) fit in a 2000 S-80? I want to convert my headlamps over to HID, but don't want to do it with cheap HID bulbs. I also like the look of the true factory Xenon HID headlamp assembly.
S70driver Jan 9, 2008 03:18 PM
RE: Volvo S80 Xenon Headlight assembly
Why don't you purchase an HID kit from SharpHID and be done with it?
Lifetime warranty if you buy the kit with that warranty and great serivce.
The kits are not cheap, they are very well built and worth the money.
woodrows80 Jan 9, 2008 03:25 PM
I have thought about doing that too. I like the look of the factory assembly. If they don't fit, I'll probably go with a kit from SharpHID.
http://i13.ebayimg.com/05/i/000/d0/a0/62ec_1.JPG
S70driver Jan 9, 2008 03:36 PM
SharpHID is great. I def. recommend them.
gordon368 Jan 10, 2008 01:46 AM
Actually my xenons burnt out and I sold them(got replacement), I have to say that the temperature that these xenon bulbs run at are HOT, and I believe they damaged my headlight -- now water gets into my headlight. But I used rainX and it is some whatbetter now.
nicolaselias Jan 26, 2008 04:33 AM
Ive been getting some problems with water in the headlight also, however mine isnt Xenon.. how did the rainx help in this case as Il really like to use it also
thanks
gordon368 Jan 27, 2008 10:42 AM
RainX is designed to bead away water, So you can put it on any glass, majority of the people just put it on the windshield. Pretty much no matter how bad its raining, you dont need to use your windshield wipers (only on high way), So you can put it on any glass surface, so i put it on my headlights thinking it would help/stop water comming in and it did.
nicolaselias Jan 27, 2008 04:18 PM
Sounds like a nice suggestion Gordon, I think il make a run to walmart this evening and get some..
Just wondering but whats the real point of the headlight wipers? Does water on the light REALLY affect your vision that much? I mean it looks classy but I dont consider it particularly necessary haha
magak2572 Jan 28, 2008 07:12 PM
The headlight wiper/washer activates when the windshield washer is being used. The premise here is that if the windshield needs washing the headlights probably do as well. It is the dirt on the headlight that reduces headlight intensity, not so much the water.
nicolaselias Jan 28, 2008 08:10 PM
Well I understand that, but stil dont seee the absolute use really...
What kind of work would be required to upgrade to xenons? Would I need a completely new assy or can i simply swap the bulbs? I know its an obvious question but iv never owned a car with xenons... thanks
S70driver Jan 28, 2008 08:14 PM
ORIGINAL: nicolaselias
Why don't you just upgrade to HID's? Simple and cheaper then you think.
majorcode Aug 16, 2013 11:25 AM
Can you recommend exact model kit from sharpHID with PN for my Volvo s80 1999? Cheers!
markusdt Apr 27, 2015 11:01 AM
Ugraded to Xenon HID, now getting fault message
I upgraded my low beams to a xenon HID system on my 2000 S80, and now I'm getting a fault message every 20 to 30 seconds for failed headlights. Is this a common problem? I love the brighter lighting, but I'm not willing to have a continually locked-in failure annunciator.
