Volvo Vapor Canister Purge Valve
Old 08-11-2015 | 07:52 AM
Sherry007's Avatar
Default Volvo Vapor Canister Purge Valve
Hi Guys,
Need help. Please view the attached picture this is
Today upon looking for any issue before drive...I found that engine's Intake manifold hose is dangled outside....and I guess it fits into this "Vapor Canister Purge Valve".....you can see the hose is in my hand in my picture.
Now the issue is there is no code at CEM, Engine Performance is OK.
1 -But when I try to put back this Intake Hose, car shuts off and this hose also sucking air inside
2- I disconnect the current from the "Vapor Canister Purge Valve" and no change in engine performance so I guess it might be the culprit.
But why no code or engine performance issue...Do I really need to buy new "Volvo Vapor Canister Purge Valve" Or can it be cleaned?
Plus Does it normal for Intake to suck air?
Please help.
Regards.
Attached Thumbnails Volvo Vapor Canister Purge Valve-8627005.jpg   Volvo Vapor Canister Purge Valve-valve.jpg
Sherry007
05-14-2014 09:12 PM
chachouu
04-08-2010 04:51 PM
holobox
09-28-2009 09:04 PM
svspeeder
06-26-2008 08:20 PM
1996850turbo
07-31-2007 09:44 PM
Quick Reply: Volvo Vapor Canister Purge Valve
