Where is A/C temperature sensor located
My a/c cuts out on hot days. I've been told that this is due toa faultyA/C temperature sensor that causes the evaporator to ice up. Where would this sensor be located on an s80?
RE: Where is A/C temperature sensor located
I would check the A/C compressor before the evap temp sensor.
When it cuts off if you can test the wire on the compresor for power. If it has power the clutch needs reshimming. |
