where are the Positive battery poles in the engine bay???
Hi I need to install a relay harness for my HID's but the battery is in the trunk. I know there are some spots to ground the car in the engine bay but I can't figure out where I can hook up something to the Positive pole of the battery... I can't just run a wire going from the trunk all the way to the engine bay that wouldn't make sense...
can anyone help me? |
if memory seeks to serve, between the airbox and the brake fluid reserve you should see a small black flap with a + on it.. pull it up and there you go, +ve pole...
Originally Posted by nicolaselias
(Post 165695)
