Window clips and door handles...
Sugar and spice and everything that pisses you off....that's what S80's are made of...Mine anyway.
Ok so here's the dilemma. I have two major issues with my car. A) My car does not fend well in cold weather. Because of freezing in the door, the clips on the regulator snapped again. I would appreciate some instructions on replacing them on my own. When I had the body shop do it they charged me 50 for labor and 10 for the clips. It's not that much but I'm sure I can do it on my own. Problem number two is a clip in my driverside door broke, so I cannot open it from the outside. I can, although, open it from the inside of my rear left passenger seat. My friend is a volvo mechanic in bridgewater...so he would definitely know how to fix it. Any instructions you can give me would be a HUGE help. |
RE: Window clips and door handles...
Which clips on which regulator?
The Handle might have broke or the plastic clip holding the rod. For the door handle. |
the blue clips that hold the glass onto the regulator. Luckily, the glass isn't broken. This happened on both front driver and front passenger windows.
They should look like a little wheel.
I think the only place you can get them is from the Dealer. |
What kind of work could the door handle potentially need?
Inner or Outer?
The Outer pushes a Peice on the door lock assembly. The Inside one has a cable running to the Lock assembly. |
