WINDSHIELD WASHER FLUID NOT SPRAYING?
ONLY THE PASSANGER SIDE HEADLIGHT IS SPRAYING FLUID? HAVEN'T HAD ANY PROBLEMS BEFORE, THEY ALL WORKED JUST FINE UNTIL LAST WEEK?
RE: WINDSHIELD WASHER FLUID NOT SPRAYING?
Maybe the inline Valve went bad pretty common.
Some will install a vaccum T in its place. That works fine but then you need to hold it longer before it sprays. It will always bleed back into the tank. |
ORIGINAL: tech Maybe the inline Valve went bad pretty common. Some will install a vaccum T in its place. That works fine but then you need to hold it longer before it sprays. It will always bleed back into the tank. |
Surprise suprise.....I removed all the standard type fuses under the hood then put them back in and it works fine now!
