A/C blows hot air under load/low vacuum
Old 03-18-2018, 06:19 PM
kiwaniansteve's Avatar
Default A/C blows hot air under load/low vacuum
I have a 98' V90 and heat blows out the vents unless the car is at idle. When I accelerate heat comes out of the vents even when the temperature control is on the coldest setting. My guess is the heater door is opening when it is not supposed to.
Any ideas on what I should check?
Old 06-19-2018, 02:18 PM
91miata's Avatar
I noticed this as well... I wonder if it's a feature that might be disabled?
Old 06-19-2018, 05:03 PM
tony1963's Avatar
This was common on the old 960 and V90. I believe that the problem sources at a leak in the vacuum reservoir.
Old 06-19-2018, 05:37 PM
91miata's Avatar
Wow! Thanks for the timely info. I'll show this to my tech and see if he'll do it...
Retlaw
04-09-2018 08:53 AM
ams
04-07-2015 08:07 AM
admasters
12-10-2013 09:24 AM
correllkp
08-08-2013 06:43 PM
shookone
06-07-2011 07:52 PM
Quick Reply: A/C blows hot air under load/low vacuum
