aftermarket O2 Sensor
Old Oct 6, 2009 | 07:07 PM
holobox's Avatar
Default aftermarket O2 Sensor
OBDII says Bank 1 O2 #2 is bad, I think that one is on the output side of the catalytic convertor. And car runs nicely until it goes into closed loop - then it gets a little sluggish coming off idle.
Any issues with aftermarket O2 sensor on this vehicle?
Old Oct 6, 2009 | 08:23 PM
Try to get a Bosch. They hate the cheap sensors.(The car)
Old Oct 15, 2009 | 07:22 AM
holobox's Avatar
I replaced O2 #2 this morning.
From what I can tell when ScanTool says "Bank 1 Sensor 2" (back of the cat) it really means "the O2 sensor on the catalytic convertor input side.
So after replacing the cat on the output side, still reporting O2 #2 as bad (0.000v dead flat) and (should have done this earlier) by plugging/unplugging the new sensor at the connector bulkhead the signal comes and goes on what ScanTool is calling "Bank 1 Sensor 1".
I bought the BOSCH OEM sensor, I'm hoping input/output are electrically the same because I'm going to swap the one I just took out with the sensor on the input side and see if that fixes the problem.
Old Oct 15, 2009 | 07:24 PM
Must be with your scanner.
Hopefully they are the same.
soduku007
Oct 7, 2019 04:01 PM
ruggles
Mar 3, 2010 04:19 PM
mctan
Feb 2, 2010 03:16 AM
Scanman
Jan 28, 2010 07:01 PM
sabydady
Jul 7, 2009 04:58 PM
