Cranks will not start!
98 s90 with 160k miles, situation, driving to work and roll to a stop light. I go to accelerate very little power, engine diesels. I was able coast to work. This is what I have checked so far spark good, compression good, timing good, fuel psi at rail good, injector pulse good, cam sensor cleaned good, all fuses and relays look functional, battery charged.
I put starter fluid in the intake, crank, no start. Last thing to check is ECU and Crank Sensor. Any other thoughts out there Volvo fans? Thanks so much in advance! :) |
What engine codes do you have?
What are your compression numbers? Maybe you have a major air issue like MAF. |
