Installing pulleys on cams
Old 07-15-2018, 07:25 PM
Rob Ellis's Avatar
Default Installing pulleys on cams
I have a 98 s90 with the 24 valve I6. Had to pull the head to be resurfaced and reinstalled.well when we pulled the head off we also removed the pulleys/sprockets from the cams. These sprockets have three elongated holes, for fine tuning of the timing. But the biggest problem is that i have a 1 in 3 chance of putting the sprockets in the same position that they came off. Does anyone have any insight as to how they should go on the cams? I believe this to be an interference motor and would like to not have to do valves immediately following this project.
Old 07-16-2018, 08:36 AM
tony1963's Avatar
You have to use the alignment tool that attaches to the rear of the camshafts to hold them in the correct position. I do not recommend that you try to "eyeball" this as there is too much variation trying to do it another way.
Here is the tool.
https://www.ebay.com/itm/For-Volvo-C...ment.TRS0.TSS0
Shawn Smith
1998-2000 model year V70
03-11-2018 07:14 PM
kthomas5
07-09-2017 08:35 AM
roosterize
2001-2013 model year V70
12-08-2013 06:38 PM
frankvftw
03-31-2013 07:20 PM
Osmenthe
02-02-2010 07:55 PM
Quick Reply: Installing pulleys on cams
