My ignition will not return...
Ok, I know it's an 960 but really, what's the difference. Anyway, does anyone know what I can do on a simple note to get the key to return to the ON position after the car is started??? This is my 2nd 960 and both has had the same problem.
Here is the problem, when I start the car and let the key go, it does not return all the way to the ON/RUN position. It hangs in somewhere between START and RUN where my windows, turn signals, and other RUN accessories will not work. I usually have to turn the key back myself so these things will work properly. Sometimes it's the little things that bother us... |
The electrical part of the ignition switch is bad.
