Cruiser |
06-14-2022 10:48 AM |
To update you need to connect the car to the internet, best way is if it can pick up your home wifi, you'll see the settings in Settings - Communication, you could however be ticked in the actual car modem settings with an expired subscription, this might be blocking out the normal function of the unit so you need to check that whole section for what's enabled and what isn't, you will need to enter your home wifi password and username if you want to try that route, once connected the car will say if there are updates.
