-   Volvo S90 & V90 (https://volvoforums.com/forum/volvo-s90-v90-40/)
-   -   Shift Lever stuck (https://volvoforums.com/forum/volvo-s90-v90-40/shift-lever-stuck-48579/)
NCdad Dec 25, 2010 10:07 AM
Shift Lever stuck
My neighbor, an elderly lady who lives next door owns a 1997 S90. She recently encountered a problem when the shift lever would not budge. She started the car and the car would not come out of 'park'. She depressed th shift lock button but to no avail. Somehow someone got it into gear and it is operating now. But I feel this problem may return as the car was not repaired. I have used her car on several occasions in the past. The shift knob already had a problem of occasionally 'popping out' when shifting. Somehow, I feel the two problems are interrelated.
Does anyone have an opinion on this ?
rspi Dec 25, 2010 05:45 PM
I had the problem in the past. Here is my solution:
http://www.atthetipwebs.com/technolo...ock_repair.htm
NCdad Dec 25, 2010 08:18 PM
Hello rspi,
Thank you for the instructions.
Slippery Jun 9, 2023 02:02 PM
Stuck shifter fix
the prob is most likely the ignition switch try turning the ignition switch back just a lil bit after you start the car that should do it don't turn it back so far that it turns the car off tho
