2002 V/S40 tuning
Old Aug 29, 2020 | 01:06 PM
Patrickane's Avatar
Default 2002 V/S40 tuning
Does anyone know where I can get a tune done on my car or have any way for the car to re learn bigger injectors? I swapped out the stock ones for for 430cc injectors and it doesn’t want to run, so I need a tune. Does anyone have software or any way to tune older Volvo’s? I’ll pay
Old Aug 30, 2020 | 02:49 PM
curious why you decided to swap out your injectors. Generally going to a bigger injector is only needed when you add a lot of boost (more than just a simple stage 1 tweak). Are you sure your replacements are compatible with the management system? Try googling "2000 Volvo S40 ECU tuning" and you'll find a few shops that will tune your ECU. Gen1 S40s don't have a soft loadable capability so they will need your ECU to insert a replacement PROM with the new program. I believe RICA and Upsolute cover this model but not sure. You can also swap out your 12T turbo for a 14T (ie like one off of a S60) - this is what came on the T4 model which would be good for 200HP easy. Even if you keep your tune, the 14T will improve responsiveness.
Newport_j
Oct 15, 2019 11:19 AM
Bpc576
Jun 23, 2017 06:31 AM
whattodo
Apr 28, 2014 05:06 AM
dcjcdc
Mar 22, 2014 10:06 AM
roytoronto
Feb 28, 2009 06:22 PM
