2001 Volvo V40 Idle Issues
Old 04-16-2018, 06:31 PM
J-T's Avatar
J-T
J-T is offline
Default 2001 Volvo V40 Idle Issues
I am having an issue with the idle on my 2001 Volvo V40. Some mornings (not all - seems to be more when it is cold and wet) upon first starting, I need to rev the gas for about 5 or 10 minutes until the idle catches. Otherwise the car will die as soon as I take my foot of the gas to put it into gear. Once I get it going, it is fine to start up for the rest of the day. I've clean the Idle air control valve, but that didn't seem to help. Suggestions???
Old 04-17-2018, 01:19 PM
tony1963's Avatar
You probably have a failing throttle body. You can start with a good cleaning by first removing the throttle body and cleaning the front and back of the housing.
Old 04-14-2021, 06:40 AM
volvo46's Avatar
did you get to the bottom of this issue im in the same situation?
sawyeronbass
04-14-2021 06:30 AM
s70guy92
04-16-2018 06:30 PM
shuldham
03-04-2010 02:12 AM
BimmerJake
05-31-2009 04:56 PM
roberius
01-11-2009 08:45 AM
Quick Reply: 2001 Volvo V40 Idle Issues
