DSA light comes on, engine dies
I’m a first-time Volvo owner – just bought this 2002 V40 from a friend last week. It’s been driving beautifully up until yesterday afternoon. I was taking the freeway home from work and things seemed normal but once I’d exited and started driving through residential neighborhoods, the DSA light came on and stayed on. Each time I stopped at a light or a stop sign the car died. I’d put it in park and it would start up just fine. No DSA light. But at the next stop, it would happen again. It happened each time I stopped.
This morning, I started the car and it died as soon as I took my foot off the brake to pull out. DSA light came on, same issue. I restarted it and drove it around the block with no issues. Anyone have any insight for me? No experience working on Volvos at all.
Thank you in advance!
Well, that makes sense about the traction because in the owner's manual it is referred to as the DSA light and says,
"Dynamic Stability Assistance
This is a system which helps keep the drive wheels from spinning. The light flashes if the road surface is slippery, the wheels are spinning and the system is working.
The control light comes on if a fault occurs in the DSA system. It also comes on if the system is switched off via the switch."
Thank you for your help man! I am a complete newbie.
Disconnect the AFM (air flow meter), start it up and see if it idles - be warned that this WILL store a code and illuminate the CEL.
If your problem dissappears then you either have a vacuum leak or a faulty AFM.
Check the small hose going from the top of the intercooler to the idle control motor, these are very common to crack and introduce air, causing a lean condition
