Engine Misfire
Old Sep 17, 2020 | 02:31 AM
jake248's Avatar
Default Engine Misfire
i have a misfire in cylinder 1 so i replaced the spark plugs and coil packs and it still cane up with misfire cylinder 1 so im kind of lost on what to do i heard maybe buying new fuel injectors, (i also ran fuel injector cleaner hoping it would help and it didn’t) was hoping someone could help!
Old Sep 17, 2020 | 09:17 AM
what happens if you swap out injectors between adjacent cylinders? Buying all new fuel injectors is a waste of money as they rarely fail -and you can either replace the bad one or find an injector cleaning service to test and clean. What did the plug on #1 look like? How does the wiring harness to the coils look (ie connectors to the coils ok?)
Old Sep 17, 2020 | 02:47 PM
What is the compression?
As others have mentioned injectors rarely fail - so I would swap 1 and 4 coil and plugs with 2 and 3 coil and plugs - and see what happens, after making sure there is compression on all cylinders.
Does the car idle smoothly? Does it use/lose coolant?
old motor head 393
Mar 14, 2022 08:59 PM
DrCarolina
Sep 12, 2020 11:02 AM
mountaincarjunkie
May 9, 2020 04:20 PM
Andrew Fritz
May 9, 2020 08:28 AM
usmcvolvos40
Jan 25, 2012 10:16 AM
