Fuses
Old Mar 1, 2011 | 10:41 AM
cherrytom's Avatar
Default Fuses
V40, 1999, 1.6v petrol. I need to replace fuse no. 5 in the engine compartment fuse box. (It controls Central Locking, Interior Lights and Radio). Fuses 5, 6 and 7 are enclosed in a yellow plastic frame which holds them in place, and I can't get either 5 or 6 out! No. 7 is blank.
Thank you. Cherrytom
Old Mar 2, 2011 | 08:49 AM
cherrytom's Avatar
Default Fuses --- problem sorted!
Volvo probably made a special tool for this job, but I found a quick and easy solution --- two small, flat-bladed, screwdrivers poked down either side of the yellow box frees it enough to pull it out. Change the fuse in the normal way, with the plastic tweezers supplied, and push the yellow box back in. It snaps tightly into place. If you've had to replace fuse No. 5, you'll need to reset the radio with its code. Sorted! = Cherrytom
zekmoe
Mar 25, 2007 09:16 PM
BravePotato7
Jun 11, 2006 12:54 PM
lane
Apr 16, 2006 05:38 PM
BigBoi4Lyph
May 24, 2005 12:58 AM
KNIN
Apr 27, 2005 01:37 AM
