-   Volvo V40 (https://volvoforums.com/forum/volvo-v40-19/)
-   -   sloppy gear box (https://volvoforums.com/forum/volvo-v40-19/sloppy-gear-box-17128/)
borgpicard Jan 30, 2008 09:32 AM
sloppy gear box
can anyone tell me, whats going on, i have to put gear into 2nd to get it into 1st sometimes ?:)
dragonslair Feb 10, 2008 12:28 PM
RE: sloppy gear box
A common problem amongst Volvos of the older type. It is usually the reverse gear that normally causes the problem. Try looking for worn bushes, (usually nylon and rubber) under the selector box from beneath the car. If you do hard gear changes they wear out very quickly. Normal gear changes, they may last up to 2 years. Also dependant on environment the car is subjected to. ie. Lots of road salt plays havoc with the aluminum bolt that runs through the selector.
Bushes are main deler parts only. Theyll cost around £14.00.
borgpicard Feb 10, 2008 02:32 PM
RE: sloppy gear box
thank you i`ll give that a try
