Transmision Problem
Transmision Problem
I have a Volvo v40 2000 1.9 manual transmision...I have problem with the transimison cause some time the gear stuck in neutral and i cant switch at any gear ...?... but when i remove the minus at the battery and i put it back again the gear start entering normaly ?...how is possibile is it any relay or electric sensor that block the gear to switch or ?...
