v40 cam seal leaking
hello im in need of some help on my volo
Cam gear seals time belt crank seal ive taken apart and done this job just about three times already with the same problem of excessive oil leaking. could the oring inside the gear be causing this ? looks like the giant leak is coming from the vvt exhaust gear ive gone to many junk yard v40s to look at the seals and i got the right one, how do i replace it ? the last three times ive put the seal on the boarder of the block .... should i put the seal on the gear first then install???? and one more question about the vvt gear, everytime ive taken off the gear i dont see what the people on the youtube videos are talking about but the gear doesnt really have play to mark twice so ive just put the gear on the mmark torqued it , then put the belt on,..... is this wrong ??? |
The VVT gear is driven by oil pressure so its likely the cause of the leak, not the cam seal. It will likely require replacement but you can search for other posts to see some discussions on rebuilding.
