brakes on a 2007 volvo v50
RE: brakes on a 2007 volvo v50
Moved from New Members Area. Notified the original poster.
Welcome to the forum.
Your car is very new and the only reason I can think of is manufacturing defect. If the brake pedal goes to the floor, it is usually a sign of air begin introduced into the brake system. Have a reputable shop bleed the system to see if the brake functions properly. If bleeding the brake fluid does not solve the problem, I can only assume that the master cylinder could be faulty. A car with many miles could have this symptom due to worn out pads/rotors but your car only has 4,000 miles so this one is probably out.
I would find an independent shop that specialises in Swedish/Euro makes and have a certified ASE Master Technician work on your car. Insist on using DOT-4 brake fluid. Or, you can visit a dealer; dealers charge more but they usually do the job right the first time.
I hope other V50 owners come in, but if you did not receive other replies quick enough, post this question in General Volvo Chat.
Best of luck,
JPN
Best of luck,
JPN
