-   Volvo V50 (https://volvoforums.com/forum/volvo-v50-20/)
-   -   UP28 Pumpe runs with engine off (https://volvoforums.com/forum/volvo-v50-20/up28-pumpe-runs-engine-off-62199/)
ltpreston Apr 13, 2012 07:09 PM
I have a 2006 V50 with standard engine package. After I shut off the engine a pump continues to run. I think it is a vacuum assistance pump for the breaks. It says "pumpe UP28" on the side of it.
Any ideas what the problem is?
adobejoe May 29, 2023 07:53 PM
Mine does the same thing. 2006 v50. How easy to replace.
habbyguy May 30, 2023 01:33 PM
Replace what? If the pump is running it may well be good, but might be commanded by sensors / modules in the car to turn on. Do your due diligence first, THEN start replacing parts...
