1999 v70 GLT Antenna Ring - P0300
Hello all,
I have a 1999 V70 GLT with 130xxx. The other day I started it up and my a/c blower wasn't working nor was anything else for that matter. I went to turn the car off when I bumped the key and everything came back on and the car was still running and the key was in the correct position. I did this a few times and things cycled on and off and the car remained running each time. The key works properly as far as turning off like it should and starting like it should. I think I may have worn this out with a massive set of keys. I run a plant so many locks door etc. Well shortly after that I threw code P0300. Could these be related? It's seems unlikely but thought I would ask the pro's. Any and all help is greatly appreciated! |
I doubt it.
