1999 v70 XC AWD 2.4 vacuum diagram
In the process of repairing bent valves, I have forgotten where some of the vacuum hose connect, (on the left side of the engine). Does anyone know where I can locate a vacuum diagram for the V70 2.4 turbo?
I have one hose that leaves the base of an electrical switch (believe it is called TCV) attached to the wiring harness between the air filter housing and the engine. It is 1.5 feet long. Diagram shows it going to a pressure gauge on the (passenger) right rear area of the engine compartment. There is no vacuum attachments in that area.
Engine is all back together and started fine. No leaks, but runs rough.
Like an engine that needs the distributor adjusted slightly. You know, the way before we used to do it. Also ETC light is on. STC light and the SRS light is on. Any suggestions?
Cleared all codes except SRS. Olny problem left is the pulsating idle. The car runs fine down the road, but at a stop the idle pulsates. Makes no difference if it in in gear or Park.
LarryNH914
Mar 5, 2018 12:11 AM
