2000 v70 headlight replacement
can any one tell me whats involved, does the bumper need to be removed?
I don't know how different your 2000 is from my 98, but on mine it's easy. Unplug the wire connector, un-do 3 bolts (2 one side, one on the other), and withdraw the entire unit from the rear.
Should be just like any 1998-1999 model 70 series.
- Remove the wiring harness from the back of the headlights. - Take a 10mm socket and take off the three bolts that hold the headlight assembly in place. - Take headlight assembly out. - Then reverse the process to reinstall. You do not need to remove the bumper to remove the headlights. |
| All times are GMT -5. The time now is 09:46 AM. |
