2001 V70 Fan Blower Motor Replacement
I've had trouble with my interior climate control blower fan squealing at startup, more persistently when it's cold out. The problem has become more frequent over the past year, so I finally decided it was time to replace the blower motor. The first post in this thread was quite helpful for my 2001 V70, but I wanted to post up pictures and a few hints regarding the specific application of a blower motor replacement in my vehicle in the hopes that these pictures can be of use to some of you out there. I also wanted to share my experience with this group as well as those on the other Volvo forum I am on. I replaced my OEM blower with an aftermarket blower from fcpgroton.com. The price was right and the shipping was fast. I will use them again for future purposes. Tools I needed to get this job done include, from left to right: https://lh3.googleusercontent.com/-j...0/IMG_0718.JPG Phillips screw driver, 1/4 inch drive extension and ratchet, T25 bit, flex-handle for 1/4 inch drive, and a pair of pliers. 1. Disconnect the battery. This keeps your electrical goodies relatively safe and keeps the foot well light off and cool while you're working with your door open. 2. The OP posted a .pdf file that states the side panel on the center console needs to be removed. I removed this panel but in retrospect I found this step can be skipped on my car since the side center console side panel was not interfering in any way. The front door sill trim panel does need to be removed to conveniently fold back the floor carpet, and the .pdf file from here provided adequate instructions for removal of this panel. 3. Remove the soundproofing panel (kicker panel) below the glove box. It was held in place by two T-25 screws. No picture of this, hopefully you've already been here to change your climate control filter. 4. Begin the glove compartment removal. Open the glove compartment and look in the space above the box off to the right hand side. You'll see the top end of the gas strut. With your fingers, reach in and tip the mounting point of camber while pulling towards you. The strut can be pulled off of its mounting point as shown by the two circles below. https://lh3.googleusercontent.com/-c...0/IMG_0708.JPG Now, with the glove box still open, you should be able to see the two tabs that prevent the box from extending beyond the initial 60 degree (estimated) opening angle. While reaching over the plastic lip behind the glove box (yellow arrow) with both hands, one for each side's tab, partially close the glove box and pull the plastic tab panel towards you to flex it enough to clear the stops (red arrow). The picture shows my index finger on the tab for illustration purposes. You need to reach behind this lip and pull it towards you, not push it away as it may appear by my finger positioning. Don't pull too hard otherwise you may be on the hunt for a replacement glove box as well. As can be seen two pictures down, the left tab was broken off on my vehicle, something that occurred prior to my ownership of this vehicle. This should now allow the glove box to fully extend, exposing all eight of the mounting screws which need to be removed next. There are three along each side and two along the top edge. https://lh5.googleusercontent.com/-n...0/IMG_0694.JPG https://lh6.googleusercontent.com/-N...0/IMG_0700.JPG Gently pull the glove box towards you and out of the hole to expose the two wire couplers and detach them as well. Now you can finally get the glove box out of your vehicle and set aside in a safe place. https://lh6.googleusercontent.com/-S...8/IMG_0696.JPG https://lh3.googleusercontent.com/-y...8/IMG_0697.JPG 5. Begin blower fan removal. reach up to the very front right edge of the floor carpeting and pull the corner of the carpet back enough to give you some room to access the blower mounting screws and drain hose. Look up under the lower edge of where the glove box used to be. You'll see the electrical connector to your blower motor. Carefully disconnect it now. https://lh5.googleusercontent.com/-8...0/IMG_0689.JPG Now comes the tricky part where you can feel the frustration of a toddler yet use some very adult words. Using your T25 bit and various 1/4 inch drive attachments, locate and remove the five mounting screws. I tried my best to get a picture of them in place, highlighted with the arrows. https://lh5.googleusercontent.com/-M...0/IMG_0685.JPG To help alleviate strain on the drain hoses, I also removed the cover panel for the climate control filter housing since the two hoses are connected to each other. I took this opportunity to inspect this filter as well. https://lh6.googleusercontent.com/-0...0/IMG_0693.JPG Your fan motor should gently drop down out of its hole. There is a plastic cover which has the drainage hose fixed to it which snaps off that can now be removed. https://lh5.googleusercontent.com/-I...0/IMG_0656.JPG 6. Remove the fan motor from the fan housing. This is done by removing the two screws off of the back of the motor and gently pulling the motor out of the housing. In my install, this was necessary because I chose to re-use the old voltage regulator that controls the fan speed and there were subtle differences between the new and old fans/motors like the position of the motor mounting holes in inside of the housing. Pictured below is the new motor on the left and the old housing on the right. Notice the new screws are at 2 o'clock and 8 o'clock but the old screws were at 10 o'clock and 4 o'clock positions. https://lh3.googleusercontent.com/-G...0/IMG_0654.JPG The old regulator came out easily by removal of two T25 screws and installed into the new housing after removal of the new motor from the new housing without any issues. After moving the regulator over into the new housing, re-insert the new motor back into the new housing and connect the motor wires to the motor regulator device. https://lh3.googleusercontent.com/-U...0/IMG_0663.JPGhttps://lh5.googleusercontent.com/-0...0/IMG_0667.JPG Here is where I snapped the new housing cover (the one that receives the drainage hose that came with the replacement fan) onto the new fan housing, starting with the large tab that inserts near the wire couplers. https://lh3.googleusercontent.com/-m...0/IMG_0673.JPG 8. Remove the drain hose from the plastic cover which is still attached in your vehicle. The Volvo hose clamp can be re-used or you can use a new hose clamp when you re-install the new cover if you damaged the old clamp. This hose is a gravity fed, non pressurized line so a snug seal is sufficient. The new replacement cover and old covers were quite similar, but had subtle differences to match the changes in the replacement motor so changing out this cover was required. https://lh6.googleusercontent.com/-N...0/IMG_0670.JPG 9. Reverse your steps to re-install the motor into the car. Be sure you align the fan housing with fan installed in the correct orientation before putting the fan up in the hole. There is a scoop type duct that sticks off of the housing that needs to be pointed to the left in order to align properly with the receiving housing up dash panel. https://lh6.googleusercontent.com/-L...0/IMG_0680.JPG https://lh6.googleusercontent.com/-r...0/IMG_0677.JPG The end outcome: I now have a blower motor that does not squeal. There is a subtle fan motor noise that was not heard with the old unit, but the noise is so subtle that I don't notice it over any normal car noises (road, radio, etc.). I assume this is because the after-market device purchased did not have the rubberized mounts within the motor housing as seen in the earlier pictures (the old housing had the soft white cushioned material and the new motor housing was strictly ABS type plastic). Overall, this project was well worth the effort and was reasonable to perform in my garage at a cost savings of about $500 less than what my local independent shop wanted to replace the motor. Full-sized pictures can be viewed if you desire by clicking here. Have a great Halloween everyone! Worldbound4now |
Thanks for posting the instructions. I have had similar problems with fans in my 850 but I usually just take them out, lube them with litium grease (in a spray can), put them back in and keep on going. I haven't had one fail yet, I think that is because I lube them before they go all the way bad.
I'm sure these instructions will help others go either way. Thanks again. |
I was going to do the remove and re-lube, but found the lower bearing/bushing on the fan motor to have an odd amount of play in it. I think it ran dry for too long.
Good catch. I think you have to get them lubed pretty quick, after they start squeeking. Within a couple of months.
Thanks, I thinking about replacing mine. I'll try to lube it first though
Fantastic write up! Thanks for posting the photos and instruction.
Great instructions. Did you have a problem with fan catching on something when reinstalled? The first time I installed it and turn the fan on, it made a fluttering noise and stopped. The new unit spins fine until I bolt it back in it's hole. The only thing I can think of is the position of the two air direction blades. above it.
lube 2004 fan blower motor
i read in this thread that you can lube the fan motor before it makes sounds, i have evrything in parts now the new used one with new recistor. were do i lube the fan motor were do i spray with lithium spray ?
Just want to say thanks for this thread even all these years later. My 02 S60 just had the Fan Blower fail after 240,000 miles. Going to be attempting this repair in the next day or so, that is if I can successfully get it out from under the dash. Having scouted it out already, your pictures and detailed description along with one other YouTube video for an XC90 from 3 years ago hopefully will do the trick. Will update when completed.
